Unstable shower pipe
Discussion in 'Shower & Bathtub Forum & Blog' started by mastermy, Jun 12, 2010.
  1. mastermy
    mastermy New Member
    Jun 12, 2010
    CA
    Hi all,
    My husband and I did a shower renovation and replaced the shower cartridge for a moen shower valve. Before we sealed it with the cover plate we tested it out. It is hard to pull the shower handle out and we can see the pipes moving forward as we do. Is there anything we can do to fix it?
    Background info: we did a whole new tile installation with new durock. We made sure the the valve plasticguard is flush with the finished wall(the tile).
    Thanks,
    Myesha
  2. jadnashua
    Depending on the valve, it may have screw holes to anchor it to a piece of wood blocking, or you may have needed to use straps or clamps to hold the pipes which would hold the valve in place. Also, you might want to take the cartridge out and put some plumber's grease on it, it may help move easier. the plaster guard is there just to be a guide on proper placement and help keep crud out while you are putting up the finished wall - it generally isn't used to support the valve (some thin wall installations may be the exception). In most, you can and should remove it once finished. Probably won't hurt anything, but most are not designed to be left in place during use. If there's no blocking in the wall, or the pipes aren't well supported, you won't be able to firm it up without getting in behind - maybe through a closet, so you don't have to tear up the tile.
  4. hj
    You need to secure the valve, but a new Moen cartridge should NOT be tight enough to cause the movement.
Similar Threads: Unstable shower
Shower & Bathtub Forum & Blog Unstable tub floor Jul 4, 2006
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Concrete shower pan; do I need a liner? Feb 14, 2017
