ultramax dirty bowl
Discussion in 'Toilet Forum discussions' started by cattledog, Jan 29, 2006.
  1. cattledog
    cattledog New Member
    Jan 29, 2006
    Portland, Oregon
    Hello--
    I recently purchased and installed a round bowl Toto Ultramax. As I expected from reading this forum, the flushing performance is very good. My issue is with residual bits of fecal matter sticking to the side of the bowl. It would appear that because of the "suction" flush with the majority of tank flow injected into the trap rather than into the bowl any bits of matter hittting or blown onto the side of the bowl rather than dropping into the water are not well cleared. There is some flow down the side of bowl during flush, and the water spot is the correct size. The toilet appears to be working as designed.
    Previous toilets I have owned, both high and low flow, seemed to direct the primary flush flow into the bowl and had better side clearing action. Perhaps the bowl emptying flush performance was not as good, but the side cleaning performance was better.
    Does anyone have any advice on how to improve the perfomance of the ultramax? Will sanagloss improve the side cleaning performance during the flush? Is there another model or brand of toilet with better clearing action on the sidewalls above the water spot but still has good bowl emptying? What about models with a higher/larger water spot?
    Thanks for any advice.
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Have you tried Chlorox toilet bowl cleaner with Teflon? Terry has a thread on this below. I haven't tried it myself, but certainly would run out and buy some if I were in your shoes.
  4. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    You beat me to it Steve. I've been using Clorox with Teflon as recommended by Terry for a week now. It just might turn your sticky situation into the desired slippery situation. My money is betting it will
    largely solve the problem.
    Let us know if you try it.
  5. SteveW
    Feb 11, 2005
    Omaha, NE
    Baaaaad pun! (Wish I had said it...)
Similar Threads: ultramax dirty
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Toto washlet seat (s350e) w/Ultramax II or integrated G400? Jan 16, 2017
Toilet Forum discussions Toto Ultramax II model numbers do not match Dec 30, 2016
