Two scary wiring mistakes in my garage
Discussion in 'Electrical Forum discussion & Blog' started by arfeller, Dec 5, 2009.
  1. arfeller
    arfeller Member
    Aug 25, 2007
    Port Angeles, WA
    While upgrading the service in my garage I ran into these gems.
    After I found the first I began removing ALL the wiring in the garage and will replace everything. Also notice, the cover on the box was made out of a thin tin cut to the correct size.
    All wires were found this way, i did not change anything or take off any electrical tape
    Luckily, I had never used the outlet with the neutral wired into the ground. It was in the back corner and out of the way. I can only imagine the problems that could have caused for me.
  2. hj
    neutral
    Actually, it might not have caused you any problems, as long as the neutral wire was not interupted between the outlet and the panel box.
  4. arfeller
    arfeller Member
    Aug 25, 2007
    Port Angeles, WA
    Truthfully, as you can see, both wires were black and I'm not really sure if that was hooked up to the neutral or hot... Did not bother to check as it was all coming out anyway.
  5. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    That would highly motivate me to check out the rest of the electrical system now rather than at later! :eek:
  6. arfeller
    arfeller Member
    Aug 25, 2007
    Port Angeles, WA
    Yep, None of the original wiring is left in the house.
    The garage is detached and was my next project. Yesterday, i removed all the wiring from the entire garage.
    At this point I feel alright : )
  7. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    Looks like the same guy that wired my house did yours. Here is what I found in the wall when I remodeled the dining room. I always wondered what that bulge in the wall was. They even put a nail through the wire, I should have got a picture of that.
  8. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    I guess that's what you get from the lowest bidder...
  9. Cass
    Cass Plumber
    Nov 12, 2005
    The nail was to hold the wire in place....
  10. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    How the heck can you install drywall over a wire :confused:
    And NOT notice it ??
  11. Cass
    Cass Plumber
    Nov 12, 2005
    you can't...it was intentional...
  12. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    It saves money on wire staples. :) Just pin the wire between the stud and the drywall to secure it.
  13. burleymike
    Nov 4, 2008
    Idaho
    That is not all they did, unfortunately I did not take pictures of the worst stuff.
Similar Threads: scary wiring
Electrical Forum discussion & Blog Dishwasher wiring all of a sudden overheats and melts Feb 27, 2017
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Feb 22, 2017
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Feb 22, 2017
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
