Twist a joint after soldering?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wheaty, Jan 18, 2013.
  1. wheaty
    wheaty New Member
    May 7, 2011
    Alaska
    I'm a novice at this stuff. I soldered the male side of a 1/2 inch "street 90" connection into the 1/2 inch female opening of a washing machine valve. Just after I'd finished and it had just begun to cool I noticed its position wasn't quite what I'd had in mind. So I reheated it a little and twisted it (about 5 degrees) to the position I wanted. Is there a problem in doing that? Thanks for any advice.
  2. jadnashua
    Probably okay...if you had run water through it, you would have had to remove, clean, then resolder. It can help to daub a little more flux on the joint when reheating one that's never had water go through it along with a touch of additional solder to help it reflow.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    No if you hold your tongue in the right place
  5. wheaty
    wheaty New Member
    May 7, 2011
    Alaska
    Thanks both. Tongue was held correctly. This saves me some worry.
  6. hj
    I usually apply a dab of solder to the connection after reheating it.
Similar Threads: Twist joint
Plumbing Forum, Professional & DIY Advice 1/4 turn twist not doable on final PVC joint--best solution? Aug 18, 2016
Plumbing Forum, Professional & DIY Advice Is twisting a P trap to offset/redirect it ever "too much" WWTD? See mockup pics... Mar 27, 2014
Plumbing Forum, Professional & DIY Advice Installing a Lako's Twist to Clean Filter Sep 2, 2013
Plumbing Forum, Professional & DIY Advice Oaty Twist'n Set flange feedback. Is it leak proof? Jan 18, 2010
Plumbing Forum, Professional & DIY Advice How sensitive are cpvc fittings to twisting May 9, 2009
