Tub/Toilet Venting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cjt, Nov 8, 2008.
  1. cjt
    cjt New Member
    Jul 13, 2006
    I am re-configuring my bathroom such that the tub is now going to be on a common waste line with the toilet. An existing 3" line leads to the toilet and is tied into the main stack on the other end that is 3" pipe downward and heads upward to vent out the roof.
    I am planning to use a reducing wye (3" to 1.5") to tie into the line to the toilet . The wye will be about 20" from the drop at the main stack and about 24" of 1.5" piping is required between the wye and the tub trap. My question is in regards to venting. Do I need to run a vent line after my wye on the tub line to tie back into my vent stack? My inclination is that it would work fine without the vent as the 3" line will always have some air in it unless the toilet is flushed at the same time as the tub drains. Also, the tub trap is < 4 ft from the main stack that is vented already.
    Thoughts??
  2. cjt
    cjt New Member
    Jul 13, 2006
  4. hj
    vent
    Still no drawing.
  5. cjt
    cjt New Member
    Jul 13, 2006
  6. cjt
    cjt New Member
    Jul 13, 2006
    How to vent?
    It sounds like a vent for the tub is well-advised. In that case, I am unsure how I can reasonably expect to vent the configuration without running a vent line horizontally.
    My tub drain wye's into the 3" common drain that is shared with the toilet about 18" from the tub's trap. I assume I have to get the vent takeoff somewhere within this 18". However, this location falls about 24" from the wall where the vent line is so I cannot go vertical until that point. What am I missing?
Similar Threads: Tub/Toilet Venting
Plumbing Forum, Professional & DIY Advice Venting For Tub/Toilet Drain Jul 26, 2010
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Wednesday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Please tell me if this venting setup will work correctly. Feb 9, 2017
