tub not draining
Discussion in 'Drain Cleaning' started by rrgnjd, Oct 3, 2006.
  1. rrgnjd
    rrgnjd New Member
    Oct 3, 2006
    Hello,
    This is my first time on the site and I thank you in advance for any advice that you give.
    My tub is not draining. In the past when this has happened I have used a recommended liquid and/or a shower snake and it has worked. Neither of these are working this time.
    The water is barely going down. When I use the snake it almost feels like I am hitting metal.
    Any advice?
    Thank You!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    The snake should work, are you snaking from the overflow or from the drain in the bottom of the tub?
    Does the drain have a strainer grid or does the drain pop up?
  4. rrgnjd
    rrgnjd New Member
    Oct 3, 2006
    It is a strainer grid. I have tried the snake from the drain at the bottom of the tub and have unscrewed the stopper lever over the spout and snaked there as well.
    I don't think there is an overflow.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Does your spout come through the tub or out of the wall above the rim of the tub?
    Will never get a snake to go very far through the drain grid.
    Must be a very unusual tub. Some were put in a long time ago. You can get access to the drain without taking the plumbing apart by going into the access side of the bath tub. Probably an old cast iron trap and most times it's hard to get any snake through it. You would be lucky if that trap were a tubing trap.
  6. rrgnjd
    rrgnjd New Member
    Oct 3, 2006
    The spout comes out of the wall above the rim of the tub.
    Perhaps I am misunderstanding the term drain grid. There is just a metal piece with holes that cover the drain. It can be unscrewed and removed. What is the access side of the tub? The house is about 50-60 years old.
    I've tried to go in through the hole where the drain stop mechanism is housed but to no avail.
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Do not take the tub drain or don't unscrew the grid where the water leaves the tub!
    To look for an access go around to the room directly on the other side of the tub faucet and look for a 20"x30" or so access door. If it's a bedroom it could be in the closet. I would guess a house that old would have one. You need to see at least where your trying to put the snake.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Why is that???? The grid should be held in by 1 screw in the middle of the grid.
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    The grid could also mean the + that's in the outlet that some plumbers use to tighten that fitting into the shoe.
  10. Cass
    Cass Plumber
    Nov 12, 2005
    You may have an old iron trap and that may be what you are hitting. How old is the house?
  11. rrgnjd
    rrgnjd New Member
    Oct 3, 2006
    The grid is in fact held by one screw and I have taken it on and off with no problem. The wall that the tub faucet is on is an outside wall, over a stairwell. The house is about 50 years old. The bath was probably renovated once.
    There is no overflow hole. I have in the past removed the lever that keeps the tub from draining, and snaked in ther, but I was told that would have no effect.
    What is the iron trap? If that's it, what do I do?
    Thanks
Similar Threads: draining
Drain Cleaning Slow draining disposal, but 2nd sink drains fine Sep 6, 2013
Drain Cleaning HELP! Kitchen Sink Draining Slow...Can't Find Clog Mar 14, 2013
Drain Cleaning Tub draining slowly after remodel Jun 23, 2011
Drain Cleaning Bathtub not draining - & waterbugs coming up Jun 17, 2009
Drain Cleaning Water draining bad, backup in basement... (Pictures included) Dec 26, 2008
