Tub leaks from around the drain. It caused adjoining wall to get soggy.
Discussion in 'Shower & Bathtub Forum & Blog' started by Mr. Water World, Mar 4, 2005.
  1. Mr. Water World
    Mr. Water World New Member
    Mar 4, 2005
    Would anyone have an easy way to repair leaks from Shower tub drain? I peeked at inside of adjoining wall (damaged already)and found puddle right below the tub.
    Thanks
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    First you need to find out where it's leaking at before you can decide on what it will take to fix it, do you know what it is that is leaking?
  4. Mr. Water World
    Mar 4, 2005
    Leak from Tub Drain
    Thanks you for your attention.
    The leak is around the tub's drain fitting. Water is seeping out from the top of the drain. This is where the round metal piece meets the tub. Around it is where it seeps out of the pipe fittings.
    When I openned the wall under the tub, I noticed water pouring out from the tub. It pours into some kind of bin or tray. It is all filled up which ends up around the bottom wall of the adjoining room. Is this tray there for a porpose? If so, is it suppose to fill up and rain someplace?
    My worse scenario is that my wife wants to renovate the whole 30 yr old bathroom. I say to wait and fix the tub for a few cents before spending thousands of dollars.
    Thank you for the help,
  5. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    If the leak is coming from where the drain meets the tub, you can unscrew it from the drain shoe, apply a "rope" of plumbers putty then reinstall. The pan that is filled with water......you've got me on that one. Perhaps someone else knows what its there for. I've never seen that.
Similar Threads: leaks around
Shower & Bathtub Forum & Blog Old tub three handle faucet leaks Apr 24, 2016
Shower & Bathtub Forum & Blog Need help identifying shower valve (leaks) Sep 14, 2014
Shower & Bathtub Forum & Blog new kohler rite temp valve leaks May 10, 2014
Shower & Bathtub Forum & Blog Tub drain replacement & checking for leaks May 2, 2014
Shower & Bathtub Forum & Blog New shower enclosure leaks at wall / base Nov 9, 2013
