Trench Drains in existing concrete
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by michelle s, Jan 11, 2010.
  1. michelle s
    michelle s New Member
    Jan 11, 2010
    SW Chicago Suburb
    Hello,
    I'm starting a dog wash business, but I'm in the preliminary planning stage. This business will require not only water supply to four tubs in a row on one wall, but also a couple of trench drains in between the tubs. There will be a series of (5) 4-foot long drains spaced 6 feet apart (between the tubs). The problem is that I will need someone to tear apart the existing concrete and then install the drains. The area of concrete to be worked on is approx. 32 x 7 feet. I know this is a very broad description, but would anyone have an estimate on how much this will cost? Any suggestions on additional features that I should consider when the work is being done? Any plumber in the SW Chicago suburbs that you would recommend?
    Thank you VERY much for your help!
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    A pet hair trap may save you alot of issues in the future and it may be required in your jurisdiction.
    I spec'd something similar to this Hair/Lint Trap for a large humane society.
  4. hj
    drains
    Cutting the concrete, installing the drains, and then repairing the concrete, may be easy as far as estimating a cost, once you know the rates in your area, but the unknown is WHERE and HOW the drains will be connected to an existing system. Only someone who is THERE and sees the actual job can determine the final cost.
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I just looked at the job and they used Petlift/Vetlift Medical Qqua Quest 58 U for the pet wash stations.
  6. michelle s
    Jan 11, 2010
    SW Chicago Suburb
    Thanks for your help...I figured I would have to wait until I get someone to the storefront to estimate costs. I was hoping to get a ballpark figure to work into my business plan to submit for some loans. Thank you once again. Any other information would be helpful!
Similar Threads: Trench Drains
Plumbing Forum, Professional & DIY Advice Trenchless Sewer Line Limitations? Aug 13, 2014
Plumbing Forum, Professional & DIY Advice Best method to determine fall with trenched pipe Jun 17, 2014
Plumbing Forum, Professional & DIY Advice Trenchless Water Line Replacement - Sleeve to prevent collapse? May 26, 2014
Plumbing Forum, Professional & DIY Advice how long for dirt to settle in sewer pipe trench Nov 28, 2012
Plumbing Forum, Professional & DIY Advice Digging a trench for a sewer line Jun 10, 2012
