Trap Primer constantly running
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GLM, Mar 3, 2010.
  1. GLM
    GLM New Member
    Mar 3, 2010
    Utah
    I have several floor drains with trap primers connected. They seem to have a constant flow and have recently started spitting out enough water into the trap to make them gurgle from the splash. Why might this be? I have previously had very high water bills, but could never find a leak and suspected the sprinklers, but now I think it's these floor drains. Why would they need to have such continuous flow? Is there anything to adjust? I don't even know where they would be connected and hope it doesn't involve tearing up concrete floors.
    GLM:confused:
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  4. hj
    "inline" trap primers have a rubber washer seal, which WILL deteriorate and allow constant flow. The best repair for these is replacement, although you may have to find one exactly the same size to fit in the pipe run. "Side arm" ones seldom fail by constantly running. They usually fail by NOT running at all. They also require replacement, but usually any similar one will work.
  5. GLM
    GLM New Member
    Mar 3, 2010
    Utah
    I cannot locate any attachments or branches from any of the fixtures in the bathroom or the sink in the adjoining room. Could the source be inside a wall or perhaps the attic space where they branch to the drains? There are 4 drains within a 10 foot diameter across two rooms. They all have a steady trickle, with occasional, but random spurts. The various drains to not all spurt at the same time or interval. Would this suggest that they have separate connections?
  6. hj
    Normally they would each have individual primers, but there could be two on each primer if the installer piped them properly. They will usually be attached to the line going to a sink, and also usually in the wall with an access door. If they did not install the door, then you have to do some detective work and hope you can find them without making excess holes in the wall.
Similar Threads: Trap Primer
Plumbing Forum, Professional & DIY Advice Continuous Flow Trap Primer Mar 30, 2016
Plumbing Forum, Professional & DIY Advice Trap seal and trap seal primer question Feb 25, 2016
Plumbing Forum, Professional & DIY Advice Running trap primer line for P-trap Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Trap Primer - Advice Requested Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Trap Primer Running Too Often? Aug 17, 2014
