Toto toilet noisy after house repipe
Rsmith99
Oklahoma
I have a Toto Gwyneth toilet that makes noise, and vibrates at the end of the fill.
It has the tsu99a.x fill valve. Last week I replaced all the internal parts of the fill valve with new spare parts. That fixed the problem for about a week. But now the noise and vibration are back.
This all started after the house was repiped with PEX. Replacing old poly.
Do I have a change in volume, or pressure, causing the problem?
I believe they said it was 80. I assume that’s what’s it’s was before.
You can get a garden hose thread pressure gauge for under $20, and often under $10. This can go on an outside hose spigot, a laundry tap, or the drain for the water heater.
Rsmith99
Oklahoma
So what should it be? And how would I reduce it if it is too high?
To reduce it, you would put in a pressure reducing valve (PRV) and probably a thermal expansion tank.
As to what it should be, the pressure should be below 80. But find out what it is.
You may be able to work around the problem by partially closing the stop valve that feeds the toilet.
Another workaround would be to try a different fill valve.
The Korky fill valves tend to be quieter than many others, but none of them really like water pressure >80psi, and if present, the seals will wear out faster and tend to eventually leak sooner than if the pressure is within spec.
Now, if you'd had some galvanized water lines and replaced them, your dynamic pressure might improve, possibly a lot, but going from poly to pex, probably not. People confuse volume with pressure...often, what you want is adequate volume, but you need pressure to get it there, so both are important.
