Toto Sweats?
Discussion in 'Toilet Forum discussions' started by vman, Feb 18, 2008.
  1. vman
    vman New Member
    Jan 6, 2008
    Massachusetts
    I just installed a Toto Drake.
    I noticed that the tanks sweats, where the old crane didn't. Is this common?
    Also, I installed the drake over an offset flange. Is this cool or do you think I'm in for some trouble down the road?
    Everything seems to be working.
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    If it works, there should be no reason to worry.
    As to sweating - it's a combination of cold water in the tank and moisture in the room. That's why our plumbing code requires either a window or a fan to remove moisture. I worked on one today that had no fan, and being winter, the window was closed. The tank and bowl were both heavily coated with condensation.
    I wiped it all off and opened the window to dry it up.
  4. jadnashua
    Make sure that the chain on the flapper is adjusted so there isn't much slack on it. A link could occassionally catch under it and hold the flapper up slightly and cause it to refill periodically. This frequent addition of cold water will cause this to happen. Once in awhile, the flappers weren't stored properly, and are misshapen and won't seal properly. If it isn't obvious, shut the supply valve off overnight and look at the tank level in the morning to see if it has dropped.
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Was the old Crane insulated? If so you might need to find a solution for your toilet sweat.
Similar Threads: Toto Sweats
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Is there any Toto 1.6 gpf double cyclone toilet with ADA compliant in the market? Tuesday at 9:11 PM
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Toto Toilet Flapper closes too quickly Feb 6, 2017
