Toto Soiree fill valve runs continuously...almost
Discussion in 'Toilet Forum discussions' started by Tojo, Jul 17, 2010.
  1. Tojo
    Tojo New Member
    Jul 17, 2010
    Bellingham, WA
    I have a Toto Soiree which was installed about 15 months ago. Within the last 4 months it seems to have developed a condition in which there is a sound of water trickling within the blue type-B fill valve almost constantly. There doesn't however appear to be any water running into the tank or down the fill-tube to the bowl as a result of this trickling water noise. The one exception to the constant running is that the sound of the water stops when another water valve is opened, such as the bathroom faucet. The trickling noise will begin once again 10 - 15 seconds after the valve for the other water use has been closed. Is there any way to adjust this fill valve to stop this from occuring or does it need to be replaced?
  2. jadnashua
    If something isn't leaking, the valve wouldn't run. If it is running, and not overflowing, it isn't the valve. Shut the water off, leave it overnight and I'll bet the tank is empty or at least down in the morning. If so, the flapper valve needs to be replaced. Depending on your water conditions (and using a cleaner in the tank will kill the rubber parts quickly), a flapper can last anywhere from months to many years. the higher the chlorine content, the shorter it will last.
  4. CarlH
    CarlH New Member
    Feb 4, 2007
    Northern VA
    I suspect you have high water pressure and failed PRV (pressure reducing valve). Since the problem stops when you open another outlet and then returns some time after closing all outlets make me think that the PRV is letting the pressure creep up when all outlets are closed. It might me a good idea to check your water pressure. If you want to check it yourself, you can check your local hardware store, plumbing supply, or big box home improvement store for a pressure gauge. It should be able to attach to a hose bib or water heater and will look something like this:
Similar Threads: Toto Soiree
Toilet Forum discussions 13-Inch Rough In Question for Toto Soirée Nov 30, 2015
Toilet Forum discussions Instal Toto eco soiree (skirted) if water line is 5.5inches from center? Jul 28, 2015
Toilet Forum discussions Toto Soirée with 13 inch rough in can I squeeze the 14 unifit or stick with the 12 Jan 1, 2015
Toilet Forum discussions TOTO Soiree and Brondell 1000 Dec 28, 2014
Toilet Forum discussions TOTO Soiree lowest flow toilet really works and unifit for 14" rough in is great Jun 28, 2014
