TOTO Nexus Tank Leaks
Discussion in 'Toilet Forum discussions' started by bjferri, Mar 16, 2008.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    I was hoping this wouldn't happen but I was prepared. The water appears to be coming from the tank-to-bowl gasket. I see droplets formed on the china around the top of the gasket and some drops coming down from the gasket. So far I've tightend the Flush Valve Nut and it seemed to have lessened but I'm not sure yet. It's so slow I'm hoping it evaporates before it developes but I'll check it in the morning.
    Even though the water isn't coming from the mounting bolts, should I tighten them more? They are a little more than hand tightened already. Will it help seal the gasket better or is the water coming from the Flush Valve Nut?
    Appreciate any ideas...thanks.
  2. jadnashua
    If you tighten the bolts a little bit evenly side to side, you can get the bowl down. I do not know about this one specifically, but most you can get the bowl nearly touching, so there is barely any flex. What do the instructions say? You need it tighter than hand tight.
  4. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
Similar Threads: TOTO Nexus
Toilet Forum discussions TOTO Nexus 1.28gal - odd throat opening? Thursday at 12:40 PM
Toilet Forum discussions Maris vs Eco Nexus & Toto tubs Mar 26, 2014
Toilet Forum discussions Toto Nexus sticky flush Jul 21, 2013
Toilet Forum discussions Toto Eco Nexus.. thoughts? May 24, 2013
Toilet Forum discussions Toto EcoNexus / Maris / 1.0 gpf Drake 2 May 12, 2013
