Toto Drake - Pink Ring
Discussion in 'Toilet Forum discussions' started by js0873, May 7, 2007.
  1. js0873
    js0873 New Member
    May 7, 2007
    I have a Drake toilet and, like other toilets in our home, it is starting to develop a small pink ring around the water line. This can be cleaned with a brush, but will then reappear in about 10 days weeks or so. In our other, non-Toto toilets, we have installed a Fluidmaster Flush N' Sparkle system, which works just fine and eliminates this problem. Will this system, which contains bleach, damage the special bowl on the Drake? If so, are there other recommendations for permanently eliminating the pink ring around the water line?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If it is just around the water line and not the whole bowl area below the water line I am going to guess it is pink slime which is a type of mold. You may want to try the Clorox Teflon treatment for toilets. It should keep the bowl cleaner longer. You could try shocking the toilet by adding a cup of bleach to the tank water, stirring, and letting it sit for an hour or so then flush 1 time and let it sit for another hour then flush 3 times to get rid of any Clorox that may be left. This may help also.
Similar Threads: Toto Drake
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
