Don't you find it amazing that people get so pumped up about a toilet?
Toto just has that effect on people!
Wanna come over and see my toilet flush!
I checked your web page and have a few comments...
Wax ring. My floor flange hole was 2.5" and I got a 3"/4" reinforced wax ring with integrated plastic funnel. I cut off most of the plastic funnel on the wax ring because it did not fit into my flange on the floor. The funnel was 2.75" but my flange was 2.5".
I would recommend using a plain wax ring. The smaller flange size that you have and the large outlet horn of the Drake can pinch the plastic funnel closed causing the drake to clog. It also may cause a leak. In short They cause more problems than they ever cured.
Buy a Toto Drake from an online retailer and check for all of the parts when you receive it.
I prefer dealing with a local supplier. Too much chance of rough handling and breakage... Aggravation avoided. I once recieved a 4' V 3/4" piece of round iron bar stock strapper a piece of wood that was bent into a horse shoe shape by UPS... It was straight at the start of its journey.
Take your sticky substance out and stick a little on the bottom of the bowl mounting bolts. Slide them into the correct location and squish them down. This should hold them in place pretty well when you set the bowl down.
I use 5/16" Brass closet bolts that come with a tinnerman nut. This holds the bolts upright and in place. See the pic below:
Flip the bowl upside down on something soft. Take out the wax ring. Mine was sitting in a platic bundt cake pan. I stuck mine in the oven for 20-30 seconds, the over didn't even warm up much. I wanted the wax a slight bit softer plus my house is @ 65 degrees or so. Pull off the plastic bundt cake pan and center the ring on the horn. Squish it down with your fingers a little to make sure it is secure on the bowl.
Heating the ring is unnecessesary. Even in the middle of winter in the Northeast US I bring the wax ring in with the rest of the supplies and by the time I have removed the old toilet and assembled the new one it is pliable enoughto set the toilet. I also set the ring on the flange not the horn of the toilet. It works for me!
Attach tank to bowl. The instructions are fine for this. The one thing you will notice is that if you tighten it the right amount it will just touch the back of the bowl. There is a little nub in back that makes contact with the bowl.
I assemble the toilet and put on the seat before setting the toilet. Making sure that the tank contacts the bowl properly and tightening the bolts is far easier while the toilet is out in the open.
Nice job! enjoy your toilet... And remember... Show it off!
