Toliet Installation Questions
Discussion in 'Toilet Forum discussions' started by Henry G, Apr 13, 2010.
  1. Henry G
    Henry G New Member
    Sep 3, 2009
    Washington, UPC code
    I'm hoping to install the toilet by the end of the week, but I wanted to double check a few things.
    1) What screws should I use to secure the closet flange to the floor? I need to drill a pilot hole through the newly laid tile, and the thinset underneath.
    2) The closet flange I purchased has holes for up to 8 screws. Should I just do 4, or add a few more just to be on the safe side?
    3) Do I glue the closet flange or not? I've heard some people tell me I should, and some tell me that's a bad idea.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I like #12 stainless steel screws of sufficient length to reach and penetrate the sub floor. Four screws will be plenty just space them around the flange. The flange should be glued to the closet bend. An friction fit PVC or ABS joint is not sealed from water or sewer gas leak.
  4. Henry G
    Henry G New Member
    Sep 3, 2009
    I never considered the sewer gas leaking. Thanks.
    Any specific kind of screw I should use since it will be partially attaching to the tile, and thinset above the wood?
  5. jadnashua
    Some tile can be quite hard, so you might need a diamond bit to make the holes. If you drill entirely through the tile with a hole big enough for the screw to fit through, make the screw long enough to grab into the wood below. The alternative is to make a bigger hole and use a plastic anchor. A flat head Phillips or square-head screw will give you a bit more grip when you tighten it down. Next time, if you notch the tile before setting, then you won't have to drill holes through the tile.
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    What part of stainless steel did you not understand? Neither stainless steel or brass will rust out, but brass is not as strong as steel.
  7. hj
    A 'slip fit" will be sewer gas tight, but NOT water tight and water is what will cause damage.
  8. Henry G
    Henry G New Member
    Sep 3, 2009
    Haha.. calm down.. geeez
    I get the part about using stainless steel due to it non corrosive nature, but I wasn't sure if there was a special screw I should use when trying to attach it partially in the thinset under the tile. The floor had to be leveled around 3/8in in that particular area.
    Thanks for the advice so far!
  9. jadnashua
    You want the screw to bite into the wooden subfloor beneath, so use one long enough for that. OR, you need to make a much bigger hole and use either a lead or plastic anchor to screw the screw into.
Similar Threads: Toliet Installation
Toilet Forum discussions PLEASE PLEASE PLEASE HELP!!! My toliet tank apparently grew and NO LONGER FITS!! Nov 10, 2016
Toilet Forum discussions New toliets Ultramax II Oct 29, 2013
Toilet Forum discussions Toliets clogging due to level pipes Mar 8, 2013
Toilet Forum discussions toliet running out of the blue / help please Feb 27, 2013
Toilet Forum discussions 2 small bath redo's - need Toto toliet reco's Mar 10, 2011
