toilet wet vent in Canada
Discussion in 'Canadian Plumbing Code Questions' started by christoff, Jun 24, 2010.
  1. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    i was wondering if you can run shower and tub drains to the 2" lav wet vent to the toilet?
    i don't know if the code is different in ontario. do the shower and tub have to have their own drain connection to the 3" toilet pipe.
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    That is not a proper wet vent design.
  4. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    what would be the proper way?
  5. hj
    The lav is a proper wet vent, but the tub and shower having "flat" vents are not proper.
  6. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    You could simply just wet vent all 3 fixtures downstream of the lav by making the lav drain 2" all the way up to the shower connection which would need to be a 3x2" wye so that downstream of the shower is a 3" wet vent.
  7. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    does this make the grade?
  8. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Nothing there will meet code. I wish I had the capability to draw it out for you but at this point I don't think you understand DWV well enough to be able to design the thing by yourself. Besides proper venting, proper slope, distance and use of fittings all comes into play not to mention how everything changes once the framing is in place. You need a professional to do this before it winds up costing you twice what it should.
  9. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    anyone else?
    btw 3 piece wet vent.
  10. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    What is a 3 piece wet vent?
  11. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Not true at all.
    [​IMG]
    The green circle is your a-typical wet vent of a bathroom group. There is nothing wrong there at all.
    The area circled in red is a concern because that appears to be a 1.5" flat dry vent. If it is you can't have a vent run flat like that until it is at an elevation of 6" above the flood level rim of the highest fixture it serves.
    The area circled in blue is a floor drain I am assuming. If it is this is also perfectly ok and hopefully it's a 3" floor drain so you can classify it as an emergency floor drain.
  12. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    the red area is a flat vent for about a foot and then straight up the wall to above the flood rim level, but i will use a t wye at 45 degrees and i think it will be acceptable am i correct mr. doherty
    and yes a 3" floor drain, and thanks for chiming in.
  13. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    As long as you come off the drain line with the vent at a nominally horizontal angle (or better you are ok). That is to say that you need to bring the vent off atleast at 45*.
    [​IMG]
  14. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    No the red area is not to code because the lav dumps into the tub drain then into the toilet line. The wet vent can not come off a branch of the main drain line.
  15. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Huh? As long as the laundry has it's own vent (which is must or else it's s-trapped) the red area is perfectly ok if the vent for the tub comes off at a nominally vertical angle.
    As for the bathroom group wet vent there is nothing wrong with what's he's drawn up.
  16. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    Not by the 09 IPC it ain't. You can not have the wet vent running off a branch from the main line. In that particular drawing there is no vent for the tub if the lav is draining
  17. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    He's from Canada and falls under NPC of Canada. Not the IPC.
  18. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The only thing that I find questionable is the section in the green circle. The 2 fixtures are not both draining in the same vertical continuous waste and vent.
    That's the way I interpret the code anyway
  19. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    You mean the tub and the sink? If so then what you quoted from the code book wouldn't apply because they're not both wet venting fixtures. Only the lav is a wet venting fixture.
    The code clause you quoted is referring to a system where you have to wet vented fixtures draining into a vertical soil or waste stack, or branch, or w/e and they are connected at the SAME vertical elevation you must connect them with a double fitting.
    There is only one vertical portion of piping that is wet vented and that's from the sink.
  20. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The qouted clause refers to 2 wet venting fixtures venting 1 fixture, in this case the toilet. The tub needs to be seperately vented and the lav becomes the wet venting fixture for the toilet.(as the latter part of the qoute states), that is the way I am interpreting it.
  21. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Krow not to be argumentative but how would you wet vent a bathroom group in a basement then?
Similar Threads: toilet vent
Canadian Plumbing Code Questions Venting Possibilities for basement toilet Jan 2, 2013
Canadian Plumbing Code Questions When is a toilet vent not required? Feb 27, 2012
Canadian Plumbing Code Questions Properly venting a toilet in Canada Jul 3, 2010
Canadian Plumbing Code Questions Toilet Shower Sink drain venting, Canada Jun 29, 2010
Canadian Plumbing Code Questions Composting Toilets Jun 3, 2016
