Toilet valve for low pressure
Discussion in 'Toilet Forum discussions' started by Daniel, Jul 23, 2005.
  1. Daniel
    Daniel New Member
    Jul 23, 2005
    We have a cabin where the water pressure is from a storage tank not much above the second floor, which means low water pressure. Toilet valves have always been a problem--either they don't work properly or filling is very slow (10 to 15 minutes). The toilet is an older (higher volume) model.
    Is there any valve that's made to work with low water pressure? We need a valve that opens farther and lets in a greater volume of water. We do have a booster pump that can be turned on for short periods, but it seems silly to have to tell everyone to turn it on every time the toilet is flushed.
    Thanks for any help--
    Dan
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The problem is not the valve. The problem is your supply line is too small for the low pressure to push enough volume of water. Please understand that pressure is not the same a volume, but you do have to have some pressure to push the water. The pressure will be the same no matter what size the pipe, but if you can increase the pressure with a pump, you will get more volume. Likewise, if you increased the size of the supply line, you'd get more volume.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    perssure
    Are you trying to fill by gravity?
Similar Threads: Toilet valve
Toilet Forum discussions Kohler K-3406 San Miguel Toilet fill valve . . . Feb 1, 2017
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
Toilet Forum discussions Kohler toilet--fill valve pops out of canister Sep 21, 2016
Toilet Forum discussions Leaking toilet - with new flapper and flush valve Sep 14, 2016
Toilet Forum discussions How to Replace a Leaky Toilet Water Shutoff Valve Sep 9, 2016
