Toilet tank will not refill properly
Discussion in 'Toilet Forum discussions' started by mdsmeck, Jan 9, 2009.
  1. mdsmeck
    mdsmeck New Member
    Jan 9, 2009
    After flushing our toilet, the tank will not refill...:(
    If I turn off the valve that supplies the water and turn it back on it works...
    I do have a replacement Fluidmaster 400A Refill Valve, but wanted to see if anyone had any suggestions before I replace it...
    Thanks In Advance...
    Mike...
  2. jadnashua
    Did you use a Watts FloodSafe supply hose? If so, replace it with a conventional one and everything will work fine.
  4. mdsmeck
    mdsmeck New Member
    Jan 9, 2009
    Nope - Just a plastic hose from the valve shutoff to the fill valve...
    Mike...
  5. hj
    400a
    IF the two valves are the same, just remove the top from the new one, or go to HD and buy a new replacement cap, and install it on the old valve.
  6. mdsmeck
    mdsmeck New Member
    Jan 9, 2009
    Just noticed something else - Seems like some type of pressure issue as if you turn on the bath tub cold water, then the fill valve starts working???
    Any ideas???
    Mike...
  7. mdsmeck
    mdsmeck New Member
    Jan 9, 2009
    Replaced the filler valve and all is good now...
    Thanks for the reply...
    Mike...
Similar Threads: Toilet tank
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
