toilet/shower vent help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by vhms1, Dec 9, 2008.
  1. vhms1
    vhms1 New Member
    Dec 9, 2008
    We are cuurently doing a remidel and adding a shower. Right now the toilet is 6" from the 3" main drain and has a 3" vent pipe. I can Tee into the 3" line right under the toilet very easily then I want to run a 2" ABS line for the shower. Will the toilet vent be enough or do I still need to vent the shower as well? If so how to I add the vent in that line? Thank you.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
  4. vhms1
    vhms1 New Member
    Dec 9, 2008
    i understand the drawing, but my main vent pipe has the toilet 6" away from it and the shower about 5' away from it. Can't I just use that vent for the shower as well? or do I need to separately vent the shower? how about using one of those inline vents if I need to vent it? Thank you.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    IPC will let you run 6' of 2" to a vent.
  6. NHJeremy
    NHJeremy New Member
    Dec 11, 2008
    If I understand your question, no you cannot vent the shower with the main stack. When you flush your toilet, water flowing down the drain will (in theory) create negative pressure, and suck your shower trap dry.
    You need to vent the shower drain separately.
    If you want to use an air admittance valve to do so, it must be accessible, at least under the IPC. It must be installed vertically, and must be installed 4-6" above the trap weir, depending on manufacturer.
    ABS is dead, use PVC.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That depends on where you are located. In some areas it is seldom seen and in others it is the dominant plastic for DWV work.
  8. NHJeremy
    NHJeremy New Member
    Dec 11, 2008
    oh no kidding, yeah dont see much of it at all up here in NH
Similar Threads: toilet/shower vent
Plumbing Forum, Professional & DIY Advice Please help! Toilet/shower/venting issues Jan 12, 2008
Plumbing Forum, Professional & DIY Advice relocating toilet/shower on concrete slab Apr 4, 2013
Plumbing Forum, Professional & DIY Advice Backflow Prevention Yesterday at 7:58 AM
Plumbing Forum, Professional & DIY Advice Please review layout. Another wet vent question Saturday at 5:12 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
