Toilet Not Level
fixit_lady
Midway, UT
I installed a new toilet. The process went OK and nothing leaks, however, it is not level. I think the floor is the problem. Since the high side is where the float mechanism is, the water does not shut off as it should, even after adjusting the float. Any suggestions on a means to level the toilet? Do I have to take the whole thing out and start over?
Deb
Idaho
Deb
An unlevel toilet will not affect the shut off of the ballcock mechanism. I would suspect debris in the valve. Shut off the water, disassemble, flush, and reassemble.
Deb
The Pipewench
