Toilet move
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by reefmkr, Dec 3, 2013.
  1. reefmkr
    reefmkr New Member
    Nov 19, 2013
    dfw
    I'm remodeling my master bath and trying to relocate toilet about 4-5 ft, can you look at my drawing and tell me if i'm doing it right?
    this would be on second floor, and garage under the bathroom.
  2. jadnashua
    If I understand things correctly, and that's not a certainty, I do not think this will work properly. You can wet vent a toilet, but you can't wet vent the shower from a toilet. Water rushing by the trap on the shower from the toilet could cause it to suck the trap dry. Since the toilet's trap is higher and internal, you can run water past it without affecting it, but not the other way around. See if the pros agree I've got this right...
  4. reefmkr
    reefmkr New Member
    Nov 19, 2013
    dfw
    Oh~~~ that make since. would be better to run separate pipe to main stack?
    btw distance between toilet and elbow would be around 5 ft and elbow to main would be 2 ft..
  5. jadnashua
    Before you make any changes, wait for one of the pros to verify I'm not all wet! Happens, not often, but it happens...I learn from the experience, too.
  6. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    What's that blue line that says 2" vent to main stack" ? Don't think you need that.
    You could possibly wye into the toilet line where it takes a hard left turn. Run your shower drain parallel to the toilet drain then vent it vertically where it passes under the wall.
  7. hj
    quote; Since the toilet's trap is higher and internal, you can run water past it without affecting it
    That is NOT the reason you cannot run the toilet past the shower drain. The reason is that the VELOCITY, and volume, of water flowing past that connection can produce a venturi effect and pull the water out of the trap. The SAME thing can happen to a toilet if the conditions are right, and it would make no difference WHERE the toilet's trap was. You also CANNOT connect the tub below the toilet's connection in the vertical pipe, without its own vent, for the same reason.
  8. reefmkr
    reefmkr New Member
    Nov 19, 2013
    dfw
    thanks everyone for explain...
    Thank you JM66208 for picture, i'll run my pipes just like in picture..
Similar Threads: Toilet move
Plumbing Forum, Professional & DIY Advice Replacing Toilet Water Valve, should I remove old ferrule and compression nut? Aug 9, 2015
Plumbing Forum, Professional & DIY Advice Extending toilet drain/flange higher - how? Valve - can I move the handle? Jul 20, 2015
Plumbing Forum, Professional & DIY Advice Planning to move toilet... and found this. Jan 10, 2015
Plumbing Forum, Professional & DIY Advice Move toilet in Master Bath Feb 26, 2014
Plumbing Forum, Professional & DIY Advice Modifying cast iron drain to move toilet? Feb 1, 2014
