Toilet flushing problem
Discussion in 'Toilet Forum discussions' started by tlbednar, Apr 30, 2006.
  1. tlbednar
    tlbednar New Member
    Apr 30, 2006
    I replaced the flapper on my toilet. Ever since then it hasn't flushed right. It wants to keep flushing for about 4 or 5 seconds before the bowl begins to fill back up. Any idea what the problem may be?
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I don't know, but if you have two small "L" shaped brackets on the bottom of the overflow tube, cut out the ring of the flapper that fits over the tube, and hook the flapper "ears" on those brackets.
    Then adjust the chain length so that it just allows the flapper to close fully.
    Should work better this way.
    Good Luck!
    Mike
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flapper
    Try the flapper first......
    Could it be that you have high water water pressure?
    Check to see that you don't have so much water coming through the refill tube into the stand pipe that it forces water back towards the opening in the flush valve, keeping the flapper from closing.
    If there is no flow adjustment on the refill tube and you have a high volume flow into the ballcock, cut a short piece of 1/8" tubing and insert it into the outlet of the refill tube, which will restrict the flow.
    Then again this may not apply to you, but it's worth consideration.
Similar Threads: Toilet flushing
Toilet Forum discussions Toilet not flushing after flood Jan 19, 2017
Toilet Forum discussions Flushing Problem with Old Toilet Jan 18, 2017
Toilet Forum discussions Wall Mounted Toilet not flushing Jan 14, 2017
Toilet Forum discussions My Toto CST743E Toilet is slowly flushing less and less properly Sep 28, 2016
Toilet Forum discussions toto toilet not completely flushing Aug 9, 2016
