scri8e
The toilet flange is too high and it is not level.
It's thick gauge steel. Appears to be soddered on with lead. Had a torch in my plumbing box but no matches. Tenant lent me a lighter and tried to get the flange off. Torch didn't touch it. That flange isn't budging for nuthin. So it must be welded on? I have a new flange. I was hoping I could fit it inside of the existing. Nope. No go.
The flange is in a cement foundation, lower unit. Flange is too high and not level. The sewer pipe comes up through the flange and passes the edge of the flange by 3/8 of a inch approx. The pipe surface edge on one half is broken like someone tried to whittle it down with nippers or something. Leaving a screwed up surface edge on the right side of the flange.
Between the steel approx 3/8 thick flange bottom and the cement floor is a distance of a 1/2 an inch or so.
What has been happening for years and years is this toilet has been a problem. The toilet has been put on.... well more like stuck on there with the wax seal made to support the toilet. After some time passes the toilet loosens up. It starts wobbling. Things start failing.
How the heck do I cure this? Only thing I can think of is to pour a square around the toilet. Like a pedestal. Mount the toilet to that? ...shrug.... That seems rather mickey mou...
Or call in the big guns that have the tools to work with that steel. Cut it off level and put a new flange in?
I'm cursing the dumb fork that did this botch job to begin with. What I am trying to avoid is making the problem worse. This maybe painful in the wallet I realize.
What is the right way to fix this? The toilet flange is ruffed in when the dwelling is built. Is the only way I can figure out how this came to be. The specs of a ruff in toilet are?
Thank you for any advice you can give me. Appreciated.
