Toilet Flange Installation
Discussion in 'Toilet Forum discussions' started by nin28, May 23, 2007.
  1. nin28
    nin28 Member
    Apr 15, 2007
    New York
    I'm about to install a new flange/pipe in my bathroom and have a question about installation. Right now I have a 3/4" plywood subfloor. I'm going to put 1/2 inch Wonderboard down, and then a layer of tile. At which layer of floor should the flange be installed? I was thinking that I would attach it to the Wonderboard layer, because going through the tile would quite difficult. Suggestions?
  2. hj
    flange
    I'm NOT a plumber, I just play one on TV.
    You and about a hundred other people. Put it on top of the tile.
  4. jadnashua
    If you notch the tile before putting it down, you don't have to drill through it. If that fails, at Lowes, you can buy diamond core drills, which may be required if it is a hard porcelain. Also, since the cement board (cbu) isn't structural, unless you need the height, 1/4" stuff is more than enough...save some money and aggravation and use the thinner stuff. Make sure to follow the instructions...cbu requires thinset underneath it; not to hold it down, the fasteners do that, but to fill any minor imperfections so it is 100% support for the tile. And, tape the joints with approved tape.
  5. nin28
    nin28 Member
    Apr 15, 2007
    New York
    Sounds good. I'll try it and let you know how it goes...
  6. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    use scrap pieces of tile.
    use cut tiles, positioned to leave enough space already, so you don't need to drill through them afterwards. Even notching the tile is a bit more work than necessary. Use scrap pieces of tile, fragments.
    david
Similar Threads: Toilet Flange
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions Odd Offset Toilet Flange Dec 21, 2016
Toilet Forum discussions Toilet Flange Height on New Tile Dec 19, 2016
Toilet Forum discussions Toilet flange question Dec 7, 2016
Toilet Forum discussions How do I Install Toilet Flange to Stubbed Pipe in Concrete Slab Nov 20, 2016
