To manifold or not to manifold?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by silverback4jack, Aug 1, 2008.
  1. silverback4jack
    silverback4jack New Member
    Aug 1, 2008
    South Carolina
    That is my question. I am currently building a house and was curious on everyone's or anyone's thoughts. Also what are the biggest and cons to the manifold system? Any help is greatly appreciated.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Manifolds are for people that do not know how to size pipe. You have a bunch of spaggetti running to each fixture from the manifold. It is also impossible to run a recirculation loop and you end up waiting at each fixture for hot water to arrive.
    I run branch and trunk lines. Less pipe, neater appearance, recirculation loop from the far end provides instant hot water. In a large home I often use mini manifolds for individual bathroom groups and mount them in a nearby closet.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I use Uponor Wirsbo PEX primarily and though a standard manifold system has a few advantages, it does use more piping. What I do like about it is the lack of fittings and the elimination of possible leaks along with flow reduction. most cases I use a modified manifolds set up whereby 3/4 or possibly 1" PEX is run to a location near the fixture grout served and from there smaller manifolds are attached and individual lines run to the fixtures. This keeps the feeder lines short and pressures more even along with a better delivery time for hot water. You can get all this info from Uponor's web site or the Wirsbo installation manual. As for the sizing issue, it's still an issue. Using PEX and manifolds does in no way circumvent the need for proper pipe sizing. And as for the spaghetti problem, PEX can and should be run neatly and hung properly. Most inspectors will not allow shoddy workmanship in this area either.
  5. silverback4jack
    Aug 1, 2008
    South Carolina
    maybe I should have also made mention that the house is being built on a slab and I was curious if the manifold would be better than just the pipe being looped in the wall from fixture to fixture.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    What size is this home? How many bath?
  7. silverback4jack
    Aug 1, 2008
    South Carolina
    nothing huge just 1600 sq ft with 2 bath
  8. Redwood
    Dec 15, 2007
    Service Plumber
    A slab that size I would homerun it. Up here we have those underground storage units... Makes a world of difference, In those I would trunk and branch.
  9. silverback4jack
    Aug 1, 2008
    South Carolina
    thanks for the info
Similar Threads: manifold manifold
Plumbing Forum, Professional & DIY Advice Proper material for outdoor risers and manifold Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Brass or stainless constant pressure manifold? Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite Manifolds...reliable? Pex size recommendation Feb 14, 2016
Plumbing Forum, Professional & DIY Advice Which 1/2" PEX home runs to share with manifold? Jan 24, 2016
Plumbing Forum, Professional & DIY Advice Mounting copper manifolds? Nov 9, 2015
