tile around tub
Discussion in 'Shower & Bathtub Forum & Blog' started by markmark, Dec 25, 2006.
  1. markmark
    markmark New Member
    Dec 7, 2006
    any recomendations for tiling around a tub/shower surround. is it acceptable to use an aqua/humidity approved drywall or should i stick with a cement backer board?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If it is not coming in contact with water, MR board / green board or even drywall should be fine as long as you have a fan for moisture removal.
  4. jimbo
    jimbo Plumber
    Greenboard is NOT adequate as a substrate for tile in a tub/shower. Needs to be backerboard with a moisture barrier under it.
    For excellent help in the tile area, see this forum: www.johnbridge.com
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    no paper faced gypsum board
    You said "tub-shower"; that says it all. The wall will get wet every day.
    It must be waterproofed. There are many ways to build the right amount of waterproofness.
    A vapor barrier behind a CBU is one method; both layers should allow drainage on top of (in front of the edge of) the tub flange.
    The other option is to put a membrane directly under the tile, so the CBU itself doesn't ever come in contact with water. Thinset (tile cement, not mastic) goes on this tile-ready membrane. There are three tile-ready membrane options: liquid gunk that hardens, a sheet that you overlap at seams, and an XPS foam board encased in fiberglass fabric and coated with cement. The last one replaces the need for any other board under it, so it saves a lot of time, mess and dust, too. It is very good.
    You cannot put paper near that amount of humidity; it'll be eaten by mold, even paper treated to "resist" mold. Even the latest technology that is better than greenboard. No organic matter near permanent humidity. No mastic tile cement either; it gets eaten by mold too! Only portland cement or epoxy cement. When i say "eaten" by mold, i mean that the organic matter will begin to smell very bad, and ultimately get rotten away over the years. The smell is most apparent when you open the walls to demolish them, but the offending micro-organism has been there for years offgassing permanently at the expense of your health and enjoyment.
    david
Similar Threads: tile around
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog replacing wall tile around bathtub - any suggestions welcomed Mar 18, 2008
Shower & Bathtub Forum & Blog Leak around tiles (I think) Feb 26, 2007
Shower & Bathtub Forum & Blog Should I DIY a Shower Pan and Tile? Jan 27, 2017
Shower & Bathtub Forum & Blog Bad Tile job? Jan 17, 2017
