thoughts on thermal expansion tanks
Jm66208
Kansas City
Now that I've installed a few thermal expansion tanks, I'm wondering how successful these things are long term. Since they need to be checked periodically, How many of you are actually following up? Are you finding that they are holding pressure, or are you having to add air to them? What happens when one operates under pressurized? Ever had one fail? :confused::(:mad::confused:
The usually fail because they rust out. T Unless the pressure is ZERO or extremely high, there is no "under" or "over" pressure, because as soon as the system is activated, the tank pressure equalizes and stabilizes at the system's pressure. The "volume" of air in the pressurized tank will change depending on the system's pressure, but that is also fluctuating with every change in pressure, no matter how slight.
Jm66208
Kansas City
So if the shrader valve fails, and the pre-charge leaks out, they are under no more than normal stress?
Gary Swart
Yakima, WA
Everything made by man will eventually fail. An expansion tank is no exception, but they generally will last a very long time without problems.
Asktom
Victor, MT
Put a goopy hock inside the cap that goes on the schrader valve and the schrader valve will never fail.
A cap with a decent o-ring rather than an all plastic cap for the Schrader valve will go a long way towards holding in the air you put in there. The bladder static pressure prior to turning the water on is preset to your actual water pressure. Then, it only moves slightly as the water volume changes from a 'neutral' position. If the static air pressure isn't preset properly, the whole bladder is already being stretched further, and it may not last as long in use. It is flexing each time the WH cycles after you stop your hot water use. As with anything, it can only flex so many times before it fails. The further you force it to flex, the shorter time before it fails.
quote; If the static air pressure isn't preset properly, the whole bladder is already being stretched further, and it may not last as long in use. It is flexing each time the WH cycles after you stop your hot water use
Once the system is pressurized, if its initial charge is less than or equal to the system's static pressure, the tank's air charge is at that same pressure, and it ALWAYS flexes with ANY pressure change, regardless of the initial pressurization. The ONLY time it does NOT flex with "WH cycles" is when it is at a higher than system pressure so it is only activated during the times when expansion reaches that pressure. It WILL actuate, however, at anything between 1 psi and 150 psi, (over 150 psi the tank's relief valve will discharge and release the pressure buildup before the tank can absorb it).
Yeah, I said that HJ! But, if you preset the tank to the water pressure, it sort of sits in the middle. If it is too low, the water will compress it further until the pressures match. If you overinflate it, you're stretching it further and the water may not compress it much. It's better to try to match your average water pressure before you turn the water on, then it sits more nearly in it's 'static' or neutral position. It always moves as the volume changes, which is why you put it in there in the first place!
