The $$$ cost of water
Raucina
I have a choice of water at $1,000 hookup and then $13.50 a month forever for standby, and about $35.00 for the first 7,000 gallons monthly. Incrementally higher after that. Or to drill a well in a very "iffy" area for 10 to 20 thousand.
I guess the water system is the best bet, but what are others paying to use 7,000 gallons a month?
Cass
The first question is are you a gambler?
Can you afford to lose 10-20K should you end up with a dry hole and then pay more to hook up to county water.
water
In this area you would not have to make the decision. If there were municpal sewer and water available, (available meaning in the area even if it cost you $10,000.00 to extend it to your property), you could not have a well, or septic tank. The quality of water from a municipal supply is monitored, whereas your well water would be whatever comes out of the ground.
Mr_Pike
Nebraska
Most folks around here on save money by hooking up to rural water. The exceptions are those who feed live stock and use a LARGE amount of water.
My choice would be rural water if I was starting from scratch.
Got_Nailed
DIY Senior Member
I would hookup. But I would setup my well for all outside stuff and maybe for the laundry. I would make sure that the meter had back flow prevention and have it set up with a single valve between the well and municipal water for when they go down.
If they had sewer I would jump on it to even if you had to toss a pump into your septic tank and pump into there system.
Raucina
Thanks for the replys. I'll go for their water, sounds pretty cheap at
$35/7000 gallons. Have to do septic for about $4,000 - no sewer system.
On further investigation, a well in this area is Russian roulette. The system wells are over 800' deep, so I guess the water district is a good buy.
