Temporary Toilet Install
Discussion in 'Toilet Forum discussions' started by C Williams, Feb 2, 2014.
  1. C Williams
    C Williams New Member
    Jan 13, 2012
    Vancouver Island
    So I’ve build our new house in a remote community in BC. The house is now to lock up, the plumbing is in and I’m just working on electrical. At my glacial pace we have a long haul ahead of us but I wouldn’t trade it for anything. We are not living there yet but are there daily working away and what we really want is a functional toilet. :p It will be months before we get a finished floor in either bathroom so I was wondering if anyone can recommend a way to temporarily install a toilet without compromising the installation of the permanent toilet flange on the finished floor? In each bathroom there is a 4†abs stub protruding up from the floor. One through concrete and the other through plywood. I don’t care which one I use. Suggestions?
    Many thanks in advance.
  2. jadnashua
    If you know the thickness of your desired flooring, you could lay some sheet goods there, install the flange at that height, and temporarily set the toilet. While not a horrible situation, ideally the flange will sit on the top of the finished floor. Or, if you have access below, you could just set it on the subfloor, and then cut it off and reinstall new when you add the finished flooring. If you plan something like sheet goods (vinyl), then just set it on the subfloor...the thickness of that won't matter, but it could if you were to add a second layer of ply and maybe some cbu, and tile.
    Most toilets won't sit properly unless the flange is either on the finished floor, or maybe as low as even...but for the finished thing, on the finished floor is still the way they were designed to fit.
  4. houptee
    houptee Member
    Aug 27, 2008
    Home Improvement Contractor
    Monmouth County, NJ
    Or maybe raise the toilet up on a temp platform above the pipe coming out of the floor. If you have a small wood pallet laying around put a piece of plywood on it cut a hole for a flange screw it to the plywood and put a piece of extension pipe and a rubber fernco to the stub coming up. Use a waxless rubber toilet gasket so you can reuse it when you permanently set the toilet.
  5. hj
    Raise the floor temporarily and use a "compression fit" flange which you can remove when ready to install the permanent floor and flooring, then install the permanent flange on top of that.
  6. C Williams
    Jan 13, 2012
    Vancouver Island
    Thanks HJ, Jadnashua, and Houptee.
    Hj's answer sounds good. I knew someone here would make me aware of a product that I didn't know existed. Now I just need to lay my hands on a compression fit flange that fits inside a 4" abs pipe. Since it is a compression fitting I'm assuming I don't care if it is PVC or ABS. I only see PVC ones online.
    You guys Rock! Thanks.
  7. houptee
    houptee Member
    Aug 27, 2008
    Monmouth County, NJ
  8. C Williams
    Jan 13, 2012
    Vancouver Island
    Thanks houptee,
    The Canadian Home Depot doesn't sell either product but our local wholesaler carries Sioux Chief so I will check with them.
Similar Threads: Temporary Toilet
Toilet Forum discussions Temporary Toilet Install? Apr 28, 2006
Toilet Forum discussions Toto Aquia Temporary Install on Concrete Floor Oct 14, 2013
Toilet Forum discussions Upstairs master bathroom toilet Wednesday at 11:51 PM
Toilet Forum discussions Toilet clogs Wednesday at 7:04 AM
Toilet Forum discussions Can hear other units flushing after installing new toilet Mar 20, 2017
