Tee with left-hand inlet for kitchen?
Discussion in 'UPC Plumbing Code Questions' started by fbacher, Jul 12, 2012.
  1. fbacher
    fbacher New Member
    Jul 12, 2012
    We are replacing kitchen cabinets, the wall is open and I'm tired of unplugging my baffle-T. I want to change to two drain lines with separate traps, etc. My choices seem to be to add a branch vent and horizontal drain OR to use one of these double tees that are at right angles to each other http://dar.proflo.com/darmanager/Query?PRODUCT_ID=165491&USE_TYPE=ZOOM_IMAGE. All openings in this tee are 2".
    The existing waste line is 2" and the vent is 1.5". If I understand the UPC correctly I can have both basins drain into the above double-Tee via separate traps and 1.5" drain lines. Exit from the tee will be 2".
    Does this sound reasonable?
  2. hj
    A picky inspectore might turn down that fitting because the "left hand" opening does not have a sweep to the connection. The right hand one does. In any case, that might be the last fitting I would use because there should be many ways to do it better.
Similar Threads: left-hand inlet
UPC Plumbing Code Questions 3" sanitary tee with dual side inlets Apr 28, 2013
