Tapping Threads in exisiting Risers with Pipe In Place
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Nov 14, 2013.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Anyone of you ever tap threads onto riser feeds that are in place......
    Option A: Not the Preferred Option just due to where the starting height would be.
    Put Female Copper Adapter and start fresh from the high height of where I would adapt to....
    Option B: Risers in wall of 2nd floor.
    Cut brass risers to preferred height of starting point
    Tap threads on risers while holding the pipe with a pipe wrench
    Hope the *torque* produced does not affect anything downstream
    I have done tons of theading on the vise, but never with pipe in *place* in the walls - all willy nilly in the air
  2. hj
    TEchnically, you are using a "thread die" not a "tap", and any plumber has threaded pipes in place at some time in their life. Not an easy task if you are doing it "by hand".
Similar Threads: Tapping Threads
Plumbing Forum, Professional & DIY Advice Tapping & Knocking noise coming from apartment walls Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Tapping a drain line "against the grain"? Nov 7, 2015
Plumbing Forum, Professional & DIY Advice Pressure reducer tapping sound Dec 23, 2014
Plumbing Forum, Professional & DIY Advice Tapping into PEX in crawl space - questions about freezing Jul 3, 2014
Plumbing Forum, Professional & DIY Advice Ticking/tapping noise PEX baseboard lines Mar 14, 2014
