Tankless water line????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jw1, May 20, 2010.
  1. jw1
    jw1 New Member
    May 27, 2006
    Hello, I am in the process of installing a new tankless water heater which needs 3/4" supply line. If I tie into a 1/2" line does the distance from the tee matter?
    I was told that I need 3/4" for the flow rate.
    I also have 135psi coming into the house which is in the process of getting a reducer but just wondering what will happen to the pressure when I go from 1/2" to 3/4" line????
    Thanks!!!
Similar Threads: Tankless water
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Time / Distance tankless water heater Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Bosch Aquastar tankless 1600 water heater firing up on it's own Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Boosting hot water capacity for tankless WH Feb 18, 2016
Plumbing Forum, Professional & DIY Advice State Tankless Water Heater help please! Oct 30, 2015
