Tankless water heater pressure relief valve location
Discussion in 'Tankless Water Heater Forum' started by Brodie's, Oct 14, 2012.
  1. Brodie's
    Brodie's New Member
    Oct 14, 2012
    Peoria Illinois
    I have a gas tankless water heater ready to mount on an external wall. It is in a finished basement with no immediate access to a floor drain and the climate is too cold for an external drain. The hot water outlet pipe travels to the old water heater location before teeing into the existing plumbing. Can I install the pressure relief valve at this location, approximately 20 ft away, if there are no shutoff valves between the tankless heater and the pressure relief valve? I then could provide a drain line from the pressure relief valve into a floor drain.
Similar Threads: Tankless water
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
Tankless Water Heater Forum Tankless Water Heater Cleaning Solution? Mar 7, 2017
Tankless Water Heater Forum Descaling a tankless water heater Mar 4, 2017
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Tankless heater house...Kitchen has no hot water, bathroom has plenty Nov 24, 2016
