Tank leaking from top and related problems
Master Plumber Mark
www.weilhammerplumbing.com
I will report my temperature readings when I have the system back online. I may try to listen for flow at the valves tomorrow as the water heater will be delivered Tuesday.
It was and likely still is code where I live to have CPVC that close to the tank on a electric water heater. Here is what the CPVC which was the closest to the tank. I will have to check before I install it and get inspected. The bottom one is on the output side and the top one is the inlet side. Both are badly discolored and the output side chipped on the inside when I cut it. I may go with 20" of copper line before I switch over to CPVC. Not sure if I like the sound of flex lines as that sounds like a weak point. Just not something I have any knowledge of using. In fact, I am not sure if I really like coated PVC, but that is for another day.
you are making too big a deal out of this... its just a lekaing water heater
ALL cpvc pipe made today is junk and gets brittle throughout the home over time..
just install the new water heater with 2 black brass craft 24 inch flex lines and
buy yourself 2 3/4 sharkbite male adaptors to go on the cpvc and you are done
also if you have a plumber install this for you.... keep out of his hair......
Kat Cali
California
Hi! I just found out our heater is leaking water from top. Looks like its been like ths for months. last time I check our heater is in October. And it wasnt like this. Do I need to turn it off? Do you think our water heater needs replacement?
rick52768
Horse Capital of the World
Wow, looks like there are many things wrong with this picture. Tape that is peeling from the draft diverter, no pipe on the pressure relief valve, leakage due to corroding connections of the water lines and what looks to be a corroding shut off valve. There could be more that is wrong, but you need a professional to help you out. I would not want to give you the wrong advise as it looks unsafe for many reasons, but have someone check it out soon. I wish you well.
Kat Cali, Do you see water up there now? If not, I would watch it. Next time you get a good rain, I would watch it again to see if water is coming in from the vent. I am not a pro, obviously. ;)
Your T+P relief valve should have a pipe that carries the water to wherever it is required in your area. That may be close to the floor, or maybe outside if you don't get freezing. This is a good job for galvanized pipe.
