t in the mainline
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tbfyou, May 26, 2012.
  1. tbfyou
    tbfyou New Member
    May 26, 2012
    Houston, TX
    I rented a 100 foot snake yesterday but have had no luck getting it in. I've watched the plumber do this before, but I wanted to get out of the deal a bit cheaper. So I drop the snake in and try to feed it into the mainline, but I have a "T" shape down there. I can not get the snake to bend enough to go into the hole. What can I do? I gotta return this machine by 12 and it is 9am now.
    ~Melissa
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Do what you should have done in the beginning. Call a plumber with professional drain clearing equipment and the skill and knowledge of how to use it. Sometime the cheap way just doesn't work.
  4. tbfyou
    tbfyou New Member
    May 26, 2012
    Houston, TX
    But I do not want to do that. I am perfectly capable I just need a bit of direction.
  5. hj
    the plumber has had YEARS of experience to get his "direction". He may also have a different kind of snake than you are using. There is no way we can tell you HOW to do it, because it is often a matter of "feel". As I asked in the previous posting, WHERE are you inserting the snake? If it is through the toilet opening, the difficulty can range from "hours of trying", to "impossible".
    You are like the customer I had a few decades ago. We were doing some remodeling and left for the Memorial Day weekend. When we returned on Tuesday, the wife asked if I could unplug the laundry sink drain because her husband had been trying to do it all weekend. he could not unscrew a pipe. I did it in a matter of a half hour or so, and as I finished, the husband came home with the biggest pipe wrench he could find, (a 36" wrench). He had rented it and was prepared to do battle with the drain that evening.
  6. jimbo
    jimbo Plumber
    Please post a photo of the Tee and the snake you are using.
    If you have to snake a line every 6 months, there is probably a problem which is only paritally fixed each time...like roots, a belly, etc.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    If you are "perfectly capable" you wouldn't need direction. Now, I'm just a novice DIY myself, but several of the responders to your questions on both threads are highly experienced plumbers with years of experience. The advice they are giving you, essentially the same as mine, is to get professional help. This is not to call them so they can take some of your money, but to give you professional advice on your problem. Yes, this is a forum to help DIY, but not every task is suited for DIY and the best advice is to know when to call for help. Very frankly, you are not going to get anyone on this forum to OK what you are trying to do.
Similar Threads: mainline
Plumbing Forum, Professional & DIY Advice Mainline backing up Oct 6, 2013
Plumbing Forum, Professional & DIY Advice Advice on how to tie into mainline for floor drain and washer waste line Jan 14, 2013
Plumbing Forum, Professional & DIY Advice where to buy PE pipe for mainline replacement Oct 3, 2012
Plumbing Forum, Professional & DIY Advice Snaking the mainline question May 26, 2012
Plumbing Forum, Professional & DIY Advice DIY Sewer Mainline Replacement Plan Aug 21, 2009
