Sweat connections near Moen Exacttemp valves
Discussion in 'Shower & Bathtub Forum & Blog' started by WendyH, May 5, 2010.
  1. WendyH
    WendyH New Member
    Apr 26, 2010
    Maple Grove, MN
    It's time to rough in the valves for the new multihead shower. The valves (1 thermostatic, 3 volume) are female threaded. We plan to sweat adapters onto pipe before screwing the adapters into the valves. However, this is a complex system in limited space, so the next connection (an elbow) may be only an inch away from one of the male adapters. How much will this heat the threaded connection? How bad is this? Moen says to go ahead and solder around the valve without removing the cartridge. Should I trust them? I'm really most worried about damaging the tape and screwing up the integrity of the threaded join. I can't really move the sweated joins farther away from the valve unless I want the therm valve and the volume valves to end up several feet apart, which would be awkward to say the least.
    This is all so much easier when I'm drafting the designs.
  2. hj
    In many cases, when I do a system like this which has threaded valves, I connect them together with brass nipples, tees, and elbows. The use the sweat joints to connect the water lines to them.
Similar Threads: Sweat connections
Shower & Bathtub Forum & Blog Bath spout rough-in/Nipple or Sweat Sep 8, 2009
Shower & Bathtub Forum & Blog Sweating tip Jul 26, 2007
Shower & Bathtub Forum & Blog Sweating new valve Jul 17, 2007
Shower & Bathtub Forum & Blog No Room to Sweat Feb 8, 2007
Shower & Bathtub Forum & Blog Shower Head and sweating involved? Sep 28, 2006
