supporting a toilet flange
Discussion in 'Toilet Forum discussions' started by LiamM, Aug 29, 2007.
  1. LiamM
    LiamM New Member
    Dec 13, 2006
    hi everyone -
    apologies if this has already been asked before...did a quick search and didn't see anything similar
    i'm in the middle of doing some renovations that included a complete gut and re-build of the existing bathroom. i contracted out the plumbing work, and i have a couple of questions about the toilet flange that the plumber installed.
    to give some background, he installed the PVC waste pipe, flange, etc AFTER i had removed the bathroom subfloor. the subfloor was still removed when he called for the rough inspection, which passed. when i installed the new subfloor, i just cut out a square to fit around the flange (which had already been glued in). this was before i knew that the subfloor had to extend underneath the flange so it could be screwed into the subfloor.
    secondly, the plumber left about 3/8" between the subfloor and bottom of the flange. i had planned on installing a 3/8" plywood underlayment, ditra, then 1/4" thick tile.
    so my questions are, can i use a flange support kit like this
    http://www.rd.com/content/openContent.do?contentId=19493 to bridge the gap between the circular flange and square subfloor cutout? i managed to size the cutout so it just allows the flange to pass through, but don't know if the support kit is meant to just replace rotted subfloor (as opposed to missing subfloor in my case).
    if i can use the support kit, can i bridge the height difference between the flange and finished floor height with an extender?
    and lastly, would both of these things be an adequate fix, or should i just bite the bullet, cut up the subfloor, and call the plumber back to cut off the existing flange and do it right?
    thanks for any advice
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Flange should not have been installed untill finished floor is set . Try the RD
    thing but I dont recamend it.
Similar Threads: supporting toilet
Toilet Forum discussions Toilet Flange not Flat/Level Yesterday at 2:21 PM
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Toilet leaks than stops Thursday at 9:59 AM
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
