Supply Line Size for Rain Shower Head
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by santanaf, Oct 8, 2006.
  1. santanaf
    santanaf New Member
    Oct 8, 2006
    Hello,
    I have been posting some over at JohnBridge.com, but was recently directed here as most of my questions thus far involve plumbing and not yet tile.
    That being said I am in the midst of my bathroom renovation and am presently running my copper supplies. So far I have everything run to the sink, toilet, and to the base of the shower rough valve. The shower is a standup shower with two shower heads and a diverter in the rough in, one regular shower head and one 8" rain. All of my supplies are 3/4" copper. My shower valve and shower heads are both 1/2" IPS.
    My concern is regarding enough volume to feed the rain shower head
    My question is....
    Should I use a 3/4" to 1/2" IPS for connection to the shower valve and then continue 1/2" copper up to the shower head
    -OR-
    Should I just use 3/4" copper throught, always using 3/4" to 1/2" IPS all over
    -OR-
    Should I be using 1/2" IPS galvanized at all points beyond the valve?
    Thanks for your time and help.
    Alex
  2. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    I was just researching the same thing... what size is the outlet for the shower head at the valve?
  4. OldPete
    Jan 4, 2006
    NJ
    Never mind, I just saw that the valve and shower head are 1/2"... I would say you'll need to use 1/2" since going from 1/2">3/4" isn't going to do you any favors since the water acn only pass throught the valve via that 1/2" connection...
    But that's just my guess. ;)
  5. santanaf
    santanaf New Member
    Oct 8, 2006
    Well, I just got off of the phone with the manufacturer and they confirmed what I had more or less planned.
    Actually, I am going to be using 3/4" copper. The 3/4" copper is slight larger than the 1/2" IPS, but the 1/2" IPS is larger than the 1/2" copper. Due to this reason they have advised to use 3/4" copper as long as the supply coming into the shower valve is 3/4" copper. This will allow more water to flow to the shower head, and since no shower head sold is more than 2.5 GPM, and I have good water pressure from the city, the 3/4" copper will allow the shower head to completely fill up. I will notice more of a pressure drop if someone flushes the toilet or uses the sink, but I can live with that.
    So I will be using all 3/4" copper and 1/2" IPS to 3/4" copper female connections.
Similar Threads: Supply Line
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Tuesday at 1:16 PM
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Faucet Supply Line Connect Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Supply lines for roman style tub faucet? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Copper Flare nut on Main Supply line Jan 19, 2017
