Sump pump pipes "gurgling"
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by pbelardo, Jan 16, 2006.
  1. pbelardo
    pbelardo New Member
    Jan 16, 2006
    I have 2 sump pumps at opposite corners in my basement. The pipe from Pump "A" follows the perimeter of the basement and exits the basement right above Pump "B" (it's a long distance). The 2" pipe is set on a slight downward slope and has a small 90 degree downward bend at the halfway point. The problem is that when the pump pumps water, I can hear it flowing through the pipe very loudly for a long period of time. Is there a way to eliminate this nuisance?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Air is Entering the Discharge Pipe
    Raise or extend the end of your discharge pipe so there is water standing in it after the pump shuts off. The end of your pipe should be at least 2 diameters (about 4 inches in your case) higher than the first low point that you encounter as you go back along the pipe in the direction of the pump, and preferably higher than the highest point in the discharge pipe. And it should always higher than the inlet of the pump (usually not an issue). That will produce a trap that will prevent air from entering the pipe as it drains.
    If it is not possible to raise the pipe, then put a trap in it using elbows, or adjust the pipe inside so the last run of pipe is up hill.
    It will take a while for the air that is in the pipe to be entrained with the water and be removed from the pipe. After that, you will not hear gurgling.
    It will also slightly decrease the flow capacity of your pump.
  4. pbelardo
    pbelardo New Member
    Jan 16, 2006
    Thanks for all the help. I think I get it. I'll give it a try sometime in the next two weeks.
Similar Threads: Sump pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
