Sump Pump loud bouncing noise.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by upanddown, Jan 19, 2007.
  1. upanddown
    upanddown New Member
    Jan 19, 2007
    Hi,
    When our sump pump in the basement runs and shuts off there is a loud bouncing noise. We tried tp replace the check valve but it still did it. It did not use to make this noise. This is the first winter we have had this sump pump.
    Thanks.
  2. carmel corn
    carmel corn New Member
    Oct 14, 2005
    One possibility would be to check how tight and secure is the discharge piping to your wall. Some builder installations have little in the way of secure bracing to minimize any movement of the pipe when the check valve slams shut. Second question, was a new pump installed since last winter? If so, is it a heavier cast iron unit or a lightweight plastic one?
  4. upanddown
    Jan 19, 2007
    It a heavier cast iron unit. Our other sump pump quit working and we replace it with this one last summer. We tried to drill a small hole between the pump and check value for air pressure but that didn't do anything. The pipes are secure.
    Thanks.
  5. carmel corn
    Oct 14, 2005
    If you are sure that there are no defects with either your pump or check valve and that there is absolutely NO movement in your discharge pipe, then another suggestion would be to dampen the pipe.
    Get some soft foam insulation or rubber and cut it to encase your discharge pipe. Make sure that there is insulation between the pipe and the wall it is attached to. Secure the insulation with tape, zipties, wire, etc. Also, look at the opening where the discharge pipe exits the house....probably above your sill plate in a joist cavity. Make sure there is no room for movement there either and fill any gaps.
  6. upanddown
    Jan 19, 2007
    We do not believe the problem is in the pipes....it is the flap in the check valve. When the pump turns off it "flaps" several times making it sound like a bouncing ball.
    Thanks
  7. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What pump did you buy? What horsepower? And how many gallons per minute can it pump at your elevation? What check valve do you have?
    bob...
  8. carmel corn
    Oct 14, 2005
    If it's the checkvalve, please elaborate on what kind it is and where. Some CV's are junk (ex. plastic Flotec at Home Depot)...replace it with a something like a Zoeller CV that has some has some steel in the flapper assembly.
Similar Threads: Sump Pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
