Suddenly - no water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by robbie, Mar 10, 2006.
  1. robbie
    robbie New Member
    Mar 10, 2006
    The water just quit with no warning (in the middle of the shower of course). The pressure guage went to zero. COuld this be something other than the pump? The pump was installed in 1992 - it is a submersible, 1/2 HP, 230 V pump. NO warning problems it just quit! And advice on what to check first would be appreciated - Thank you!
  2. Gary Slusser
    Retired
    You should check the electric for power to the pressure switch, then the well. Then check the power cable for no shorts or opens and then the ohms of the pump motor windings. www.franklinelectric.com has them.
    If you have a 3 wire type pump, you'll have a control box by the pressure tank in most cases. It could have a bad capacitor or relay. Franklin will tell you how to check it.
    You could have a power cable that has shorted or a leg open. Or the pump motor quit. Or the thermal overload opened for some reason and shut off the pump. You could have a low pressure safety switch and have to lift the handle to get the power to the pump (or control box) and then when the pressure is above 20 psi, let go of the handle to reset the switch.
Similar Threads: Suddenly water
Pumps and Tanks Well Forum & Blog. Water is life. no water for Christmas, please help! well pump suddenly not cycling Dec 24, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Water Pressure Has Suddenly Started Coming and Going Oct 1, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Red coloered well water suddenly Aug 25, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Well water pressure normal than drops suddenly Jun 15, 2010
Pumps and Tanks Well Forum & Blog. Water is life. suddenly no water!! Jul 7, 2009
