Submersible pump well problem
metrogal
east coast Georgia
Starting about two months ago the underground sprinkler system started to malfunction. I have checked for water leaks in the system, ohm leaks at the control box and am now to this: water pressure at the house is fine, but I have not turned on all water taps at the same time. when the sprinkler system start up, the well pressure gauge shows 50#, after the system runs for 2/3 min. the pressure gauge starts to fall and shortly thereafter the water pressure/streams start to diminish, the gauge goes the 30, needle jumps and then goes to 20 , at that point I have just gurgles at each of the sprinkler heads. I am concerned the submersible pump is starting to fail.
Simplepump guy
Nevada
I have the exact same problem with my system. Did you get it fixed? If so, what did you do? Thanks.
