Stinky dishes, PLEASE HELP
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mkaufman, Apr 4, 2014.
  1. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    4 years ago we had our kitchen remodeled. It was completely gutted. We put in a brand new Bosch dishwasher and brand new everything else. Since that time, we have an on-again, off-again awful odor on our dishes when they come out of the dishwasher. The only constant I can find is that it usually happens more when we have had a lot of rain. I have tried to EVERYTHING including switching out the AAV, cleaning the dishwasher, bleach in the disposal (sometimes I can smell it coming from the sink), lemons, baking soda, even Thrift. I have had countless plumbers tell me nothing is wrong and the appliance repairman. Unfortunately the dishes smell so bad you can't eat off of them. I am at a complete loss!
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    You don't smell something in the shower?
    Does the inside of the dishwasher smell?
    If you stopper up the sink drains and put an inch or so of water in the sinks for a while, does the odor go away?
    Do your gutters drain away from the house?
    Do you have a crawl space?
  4. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    Shower does not smell.
    After we run the dishwasher and open it, if the smell is bad u can smell it right away. Throughout the day the inside of the dishwasher does not smell.
    Yes, there is no odor when I fill the sink.
    Gutters are piped away from house. There is a pipe running directly next to the house right outside of where the dishwasher is.
    Yes, we have a crawl space.
    Thanks for helping:)
  5. Reach4
    Sep 25, 2013
    That is interesting. So as I understand, you get an odor from the dishwasher sometimes when you open it, and not others.
    If the dishwasher is closed and there is water in the sink, there is no odor.
    My reasons for asking about gutters and crawl space was wondering if something was getting wet under the floor and sending odors up. That would occur despite the sink having water in it. So it would seem that the "water seal" situation is not working, and that sewer gasses are able to work their way up from the sewer. I am not a pro, but am just trying to think it through.
    I think a photo of the trap area under the sink would be useful to see if there is something that people could identify as a potential cause of your problem.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What model is your dishwasher ?
    You should look in the manual and see how to clean out the Food Grinder.
    It may have some dead food in it.
    Or it may not be pumping out completely.
    Good Luck.
  7. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    This might be where the problem is located. A couple photoes of how it is tied into the plumbing and how the drains run under the sink might be helpfull. Does the drain line from the dish-washer loop up to the top of the cabinet?
  8. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    Here is a picture of the plumbing under the sink. The thing that traps food in the dishwasher has been cleaned multiple times.
  9. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
  10. wondering
    wondering Member
    Dec 10, 2006
    Alabama
    My sister had the same problem with hers, also a Bosch. She was using the dishwasher tablets but switched to Cascade Powder and also changed cycles, maybe to " Auto" instead of what she was using and she hasnt had an odor since. Maybe that cycle gets hotter I am not sure but that and Cascade fixed hers.
  11. Smooky
    Apr 4, 2011
    North Carolina
    Humidity does affect odor so when it rains and the humidity is higher you may notice the odor more. The picture of the plumbing looks good when I invert the screen. I know above you changed the AAV but they are not all created equal and some cost a lot more than others. I like studor vents. If you have some cheap brand I would change it for a studor mini vent.
  12. Gib
    Gib New Member
    Apr 2, 2014
    If you ran your hot water only out of faucets and their is no smell follow next suggestion.
    Disconnect dishwasher drain hose from food disposal. Cap food disposal outlet opening for dishwasher using hose clamp. 1-1/2" tubular pvc, slip, dishwasher branch tailpiece,(you need to buy) replaces extension piece located between the trap and the food disposal. Run dishwasher.
    you should be good.
  13. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    I'm no plumber, but two things look wrong to me. To clarify, is the black thing on the right a disposer?
    1) The "trap" is upside down making it useless. There appears to be a direct path for sewer gas to enter the dishwasher and sink.
    2) The drain from the dishwasher should have either a "high loop" or an air gap depending on your local code, to prevent wastewater from backing up into the dishwasher.
    Maybe there is more going on that we can't see from the pictures, without being there its hard to tell.
  14. Gib
    Gib New Member
    Apr 2, 2014
    the picture is upside down...
  15. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Doh, I knew that ... now that you mention it.
  16. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Turned right sued up
    [​IMG]
    JR
  17. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    We had the same issue with a new Samsung dishwasher. We bought it from a big box store. After researching online there were lots of similar complaints. Ours also never dried dishes thoroughly. Sales guy said it had something to due with the European drying process. He said same complaints from customers with LG and Bosch.
    We swapped it out for a Kitchenaid and problem solved. No odor and dishes come out dry.
    JR
  18. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    I changed it out a couple of days ago. No change to smell though:(
  19. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    I changed out the AAV a couple of days ago. Did not affect smell.
    Also, after remodel dishwasher was hooked to the PVC below the garbage disposal, we moved it to connect to the garbage disposal to try and cure the smell problem.
  20. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    We checked crawl space yesterday. Everything looks to b in good order.
  21. Mkaufman
    Mkaufman New Member
    Apr 3, 2014
    Nc
    Thank you for your help. After countless dollars spent and hours of trial and error, this simple solution has helped more than anything else. There is still a slight odor sometimes, but not nearly as bad. Can you please confirm she moved to the "auto" cycle? I just want to make sure I'm not missing anything.
    Thank you!
Similar Threads: Stinky dishes
Plumbing Forum, Professional & DIY Advice Is the stinky smell by the bathroom from the septic tank? Nov 20, 2015
Plumbing Forum, Professional & DIY Advice Stinky front loader Bosch washing machine - what to do? Nov 2, 2015
Plumbing Forum, Professional & DIY Advice Stinky Drain Apr 29, 2014
Plumbing Forum, Professional & DIY Advice another stinky kitchen drain and dishwasher problem Oct 2, 2013
Plumbing Forum, Professional & DIY Advice replacing Toto seat mounting software due to permanently stinky parts? Feb 27, 2013
