Steady stream of water from my Bath Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by mic, Aug 17, 2006.
  1. mic
    mic New Member
    Aug 17, 2006
    I have a Delta Classic Pressure Balanced Valve similar to model: T13022
    There us a steady stream of water coming out from the tub spout. I removed the tub spout and can't find any shut off valve. I assume it's in the handle area. When i plug the tub spout up it comes out the shower head. Any ideas? I will post pictures if I have to.
    Thanks for your help
  2. jimbo
    jimbo Plumber
    A spout is a is not a source of water. Your control valve is leaking.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    To fix your leak, you need to shut off the water to your shower/tub, remove the faucet handle, backer plate, and stem, and replace the seats and springs.
  5. hj
    If you think you can stop a leak by removing the spout, you need to call a plumber before you damage something and have to replace the valve.
Similar Threads: Steady stream
Shower & Bathtub Forum & Blog Shower has weak stream, not sure what to do Jan 25, 2013
Shower & Bathtub Forum & Blog delta push button diverter streams water Sep 30, 2005
