Square D 2 pole breakers
Discussion in 'Electrical Forum discussion & Blog' started by rockycmt, Oct 11, 2012.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    I was in Hdepot this weekend. I was looking for a 2 pole SqrD 20Amp skinny space saver breaker. Do they make these? I see them in the other brands there.
  2. Glennsparky
    Glennsparky New Member
    Oct 4, 2012
    http://www.theoviedoelectrician.com/
    Oviedo, FL near Orlando
    Call your local Square D distributer. That breaker is called a quad. Square D makes QO style and Homeline house breakers. They don't make QO quads. They may make Homeline quads.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Many SqD replecements are made by Connecticut Electric. They are UL listed replacements, and they make both the QO and Homelines, which are not interchangeable . They will be clearly labeled as to SQUARE D Type...... A thin 2 pole 20 should be available.
  5. hj
    quote; That breaker is called a quad.
    A "quad" is a two pole breaker with FOUR levers, not a single pole with two levers, which is what this person is asking about. Incidentally, WHY do you need this double pole breaker? Not for a 220/240 circuit, I hope. In addition, in order to limit the possibility of overloading the panel, they usually restrict the location and number of "piggy back" breakers you can install. They do not always fit in every single pole slot.
  6. Glennsparky
    Oct 4, 2012
  7. Glennsparky
    Oct 4, 2012
    I couldn't find any Square D replacements on Connecticut Electric's website. This product
    http://products.connecticut-electric.com/inventoryD.asp?item_no=UBITB220C&CatId={7DF35B55-1A7B-4294-BC01-656D1BCDF640}
    may physically fit in a homeline panel, but it is not listed for it. So, not legal.
    Sorry, I can't get this link to work. Can anyone help?
  8. jimbo
    jimbo Plumber
    San Diego, CA
    Looks like I mispoke. SOMEONE makes replacements, but it appears it is not connecticut. Of course, OEM Schneider ( SQ D) are available now also. A few years ago, they were off the market because of a massive chinese forgery/fakery problem.
  9. hj
    Glennsparky. He is looking for a single device breaker with two terminals. They can come in a "half sized" format with the two levers side by side, or piggy back with the two levers in the same plane. But in either case they are on the same polarity and only require a single slot on the panel, assuming the slot is not one which "rejects" tandems. "Quad" breakers usually have a "double pole" breaker and two single poles.
Similar Threads: Square pole
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Jan 26, 2015
Electrical Forum discussion & Blog Square d May 14, 2010
Electrical Forum discussion & Blog Square D panel? Dec 21, 2007
Electrical Forum discussion & Blog Square D Circuit Breaker Recall Nov 2, 2007
Electrical Forum discussion & Blog Square D well pressure switch Sep 23, 2007
