Sprinkler startup fail
Discussion in 'Irrigation / Sprinkler Forum' started by ronnieray, May 12, 2013.
  1. ronnieray
    ronnieray New Member
    Nov 10, 2009
    Minnesota
    I went to start up our sprinkler system today and everything went well except I have very low water pressure at the heads. They valve opens but the heads hardly rise out of the ground and I can piss farther than they throw water. It is the same for all the zones. All the pipe valves are fully opened and I don't see any water puddles any where on the lawn that would indicate a broken line. I walked the entire property and no puddles.
    It is the same for all the zones which suggest to me the problem is at the main water line. I replace the main valve in the basement last year. I check the valve operation and there is good water flow. Could the back-flow preventer valve cause this problem. I took it apart but saw no obvious problems.
    Thanks for the help.
Similar Threads: Sprinkler startup
Irrigation / Sprinkler Forum Sprinkler startup May 18, 2010
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Sprinkler head problem Sep 18, 2016
Irrigation / Sprinkler Forum Inground sprinkler system SPLITTER? Sep 8, 2016
