Sprinkler Head Question
Discussion in 'Irrigation / Sprinkler Forum' started by maxmitchell, Mar 8, 2007.
  1. maxmitchell
    maxmitchell New Member
    Mar 8, 2007
    Texas
    Thank You!
  2. ed the head
    ed the head I have been in irrigation over 25 years
    Mar 8, 2007
    Irrigation
    Texas
    sprinkler head
    First question, there isnt a problem installing the risers for the plants.But the rule of thumb is you should water plants seperate than grass.Grass needs more water less often and plants need less water more often.
    Second Question,You should never glue a riser in to a fitting. Because if it breaks off then you have to replace the fitting.You should use a swing joint or a flecks line.
Similar Threads: Sprinkler Head
Irrigation / Sprinkler Forum Toro sprinklerhead not retracting. Apr 18, 2016
Irrigation / Sprinkler Forum Have sprinkler head output but need to irrigate narrow strip Jul 8, 2012
Irrigation / Sprinkler Forum Sprinkler heads only coming up halfway Mar 15, 2012
Irrigation / Sprinkler Forum Sprinkler Heads Feb 5, 2012
Irrigation / Sprinkler Forum Additional sprinkler head Oct 11, 2011
