Special Fitting?
Discussion in 'Remodel Forum & Blog' started by Joe J, Jan 23, 2005.
  1. Joe J
    Joe J New Member
    Jan 23, 2005
    Hello all,
    I am in the process of a complete remodel of my 3/4 bath. I have encountered an unusual PVC Y fitting. It is a 7 1/2 long, 3x4x2 y. The 4" section connects to the old 4" cast iron but it is labeled Permafit and has the # 45174 on it. Is this a special sleeve or a special Y fitting? I googled Permafit and Colonial Engineering and could not find anything. Extra space is nonexistant so I must find a replacement. Please advise.
    Respectfully,
    Joe
  2. macleod
    macleod New Member
    Jan 22, 2005
    pasadena, ca
    Try a local plumbing/ pipe supply house, look at Nibco website
    Joe,
    I also encountered an unusual fitting in my bathroom remodel. You can try looking up the fitting on a manufacturer website like Nibco - www.nibco.com, they make plastic fittings.
    I found that to actually buy the fitting, I could not go to HD or Lowes, I had to go to a couple of pipe supply stores until I found one that did enough volume to stock the part I needed, a 4" elbow with low heel vent inlet.
    In my area, Ferguson was that store - I think they are a nationwide chain of plumbing supply houses. If you take the fitting into the store, they may be able to help you. This is definitely one area where the service at a plumbing supply house is worth it. Plus, they may have doughnuts if you go early enough. ;)
    good luck,
    Jason MacLeod
    [​IMG]
  4. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Could you post a picture of the fitting?
Similar Threads: Special Fitting
Remodel Forum & Blog Modern Masters Metallics & Special FX Finishes Dec 20, 2006
Remodel Forum & Blog Retro fitting a victorian tub with safey rails Nov 2, 2008
Remodel Forum & Blog suggestions for fitting vanity top Mar 31, 2008
Remodel Forum & Blog Fitting Door Slabs in Existing Jambs. Feb 14, 2008
Remodel Forum & Blog PEX Directional Fittings vs Flow Volume Aug 4, 2006
