spa pump cycling off and on
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by hockeydad, Oct 5, 2009.
  1. hockeydad
    hockeydad New Member
    Jun 17, 2009
    I bought a remanufactured spa pump to replace my leaking one. It's 2hp, 2 speed. Every thing was working fine before, except for the leak. I installed the replacement pump and it would run for a while, then turn off/on/off etc... after just a few minutes, it would only run for one or two seconds, then turn off for 10 or more seconds. I called the company I ordered from, and they sent another pump (also remanufactured), from the same drop-ship company. It's doing the same thing!
    At the connection to the pump I measure a steady 115 vac when on low speed, so I figure the panel is putting out good power. I also hooked the pump straight up to my house current 115 vac to the low speed and common terminals. It cycled off and on with this set up as well.
    So, did I get two bum pumps? What else can I check to see if nothing is screwed up with my control panel? I really want to get my spa running again, but I don't want to buy another pump if the problem lies elsewhere. It's been too long since I received the second pump (my fault - I let it sit due to frustration) and the company is brushing me off.
    Thanks for any help.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Sounds like two bad pumps. especially if you bypassed the control panel.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Are you sure the pump is 115 and not 220? Many pumps can be used on either voltage just by switching some wires in the pump.
    John
  5. hockeydad
    Jun 17, 2009
    The pump is a 230 Vac. Four wires, green ground, white common, red hot 115 Vac, and black hot 115 Vac. The red goes to one terminal which is labeled low speed. The black goes to another terminal labeled high speed. I supplied 115 to the low speed and common terminals and got it to run on low speed, but it cycled off and on. Would the pump draw from the other 115 to run on low speed? My spa control panel is not putting out any voltage across the high speed terminal and common when set to low speed. Could this be the problem?
Similar Threads: pump cycling
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling of well pump when no water is running Aug 2, 2015
